- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I'm new to Revit, I've been searching but I cant seem to explain to google well enough so, straight to the source. I am drawing up a simple skillion roof structure like an open carport. My Columns (100mm steel posts) have tabs on them for bolting, but they are behaving strangely. I have angle cut the top of a column to 20 degrees, and want to put a tab on the low side, also at 20 degrees, so a purlin will sit on top and be bolted from underneath. The tab, however wont associate with anything and is miles high up in the drawing and i cant seem to get it to attach to the column in the correct position.
Also I'm not sure how my void extrusion works. In the family it has shown to cut the post on the 20 degree angle, but in the project, the top of the post is still square. I have attached the family and some screenshots
Any help on this would be appreciated.
Ta
Grant Jones
