Colour Fill Legend Not Displaying Correctly In Plan
Message 1 of 17
Hi, I have a plan that shows some rooms with the correct colour fill for its department but one room is showing white ( no colour ).  We have turned off floors, even checked they are at the right level relative to that particular floor and set the colour fill pattern to `none`.  Below is the plan in question.  The floor actually is within the red highlighted area which is showing the correct department colours in the circulation and other purple community dental room.  Any ideas how to get the office to show purple too other than cheating with a colour fill region!
Replies (16)
Message 2 of 17
syman2000
Can you check and see if the Plan is set to Hidden and not wireframe?
Message 3 of 17
Delete the plan region see what happens.
Message 4 of 17
Yep, plan is hidden line.
Message 5 of 17
martijn_pater
What's the height of this room in section related to the cut plane?
Message 6 of 17
syman2000
Check and see if you have plan region as other mentioned as well as cut plane. Also check if your color scheme location is set to foreground.
Message 7 of 17
Do you mean the green dashed box?  Thats a scope box a colleague did.  Made no difference deleting it though. A little lost with this one.
Message 8 of 17
If it is not a plan region then ignore the comments. A few things to check:
- Reveal hidden elements see if you have any plan regions in that view
- Check the Height Offset from Level of the Floor. If it is above 0 then either set it to not Room Bounding or set the Level's Computational Height to be above that value.
Message 9 of 17
Room is approx 3m high with the view range as per the below.  But I don't understand if it was a view range then wouldn't it affect the other rooms too?  Also, not sure about Plan region as I believe my colleague just duplicated a floorplan and then created the required template to show the depts.
Message 10 of 17
Not sure what you really mean for your Height Offset point.  All walls are at the right height above the level (IE at 0 above the level).  The only thing unusual is the orange area is an extrusion that previous colleagues did when drawing the plans over the CAD survey ( its an old 1899 building ).  The height of these extrusions does not go up to the floor above and when I change the extrusion end length I get the warning message shown below.  Also, not sure how to change Computational Height.  Apologies for being a pain!
Message 11 of 17
I wasn't talking about walls but floor. Select that floor and look at its properties for the value of Height offset From level. About the Level's Computational Height, open a section/elevation where you can select the Level then you can access that parameter. Again, you may or may not need to change it, depends on the answer of the first question.
Message 12 of 17
This project has the floor (finish) set at 130 above the level.  I have changed the computational height to 1000 but still nothing showing for the purple dept colour.  What I don't understand is why if the floor could be blocking from showing the department colour then why isn't the same floor not doing the same in the other rooms that it is in.  Its the same with the a different floor that goes in the other rooms ( which is also set to 130 above level ) as in the correct dept colour shows.
I didn't draw this project just been asked to see why the problem is occurring.
I presume you can't delete the dept colour from an individual room plan - even if the Identity Data still says the Dept?
Message 13 of 17
What if you turn off the floor?
Message 14 of 17
The floor had originally been turned off.  It hasn't made any difference on or off.  Still just the one room not displaying the dept colour.
Very lost with this one!
Message 15 of 17
Okay boss share the file then.
Message 16 of 17
Hi @ToanDN I did send you a dropbox link via PM the other day.  Just wondered if you had managed to take a look?  Oh, just noticed I hadn't identified for you the problem drawing! But note that my colleague has now included a purple filled region as a temp work around.
Message 17 of 17
martijn_pater
You could share it on the forum, I suspect Toan gets the most questions here already...
