colorbyparameters in a selected view
andrea.adami
andrea.adami
Hello everyone, I am a newbie so I apologize if the question is not relevant. I need to color an element (wall) according to one parameter. I did it with ColorbyParameters from modelical.
But I would like to apply this only in one view. Do you have any suggestions?
thanks in advance
francfiles
use filter
francfiles
francfiles
That's exactly what View Visibility and Graphic Overrides is for.  You can override Visibility/Graphics in a View by Element, by Category and/or by Filter.
Override Visibility and Graphic Display of Individual Elements | Revit Products 2016 | Autodesk Know...
Override Graphic Display of Element Categories | Revit Products 2018 | Autodesk Knowledge Network
Apply a Filter | Revit Products 2018 | Autodesk Knowledge Network
syman2000
I would use filter in this case. Once you have parameter, you just give value and then set the surface pattern to solid color of your choosing. See screenshot
andrea.adami
Thanks for the suggestion, I will try immediatly
