Color scheme not appearing..
Message 1 of 10
drived me crazy.. has apparently something to do with the floors, when I make them transparent the colors appear, but also appears the room (x) cross thing ..
here in the image the colour appears where there is no floor (clear storey, not yet seperated through room lines) also filling the base of an RPC! ????!
HELP!
Replies (9)
Message 2 of 10
cbcarch
Do you want to see colors? i.e. do you want Color Scheme turned on?
Do you have an Underlay turned on? If so, set to None.
Try setting Color Scheme to Foreground.
Maybe use a Plan Region if you have a multi-story space to set the View Range independently for that space.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 10
hi @cbcarch , nope it did not work, yes the colours are there when I hide the floor they appear (but together with the X room symbol lines) ... there is nothing exceptional in the geometry..
Message 4 of 10
My initial thinking is that other graphic overrides - either by Element, by Category or by Filter - are acting on the floor in the view.  Is it replicable in new Views?
Message 5 of 10
syman2000
Can you upload the file?
Message 6 of 10
@barthbradley it is the same in other floors, i created a wall rectangle here in the image on the left and worked there because there is no floor placed.. can there be some sort of conflict between rooms and floors?
Message 7 of 10
@syman2000 @barthbradley  here is the file..
Thanks!
Message 8 of 10
Message 9 of 10
syman2000
Looks like your floor has surface material set to solid white. This is what hides the room color.
Message 10 of 10
thanks @syman2000 !!! perfect!!!
