Message 1 of 12
This is something that I have spent some time on in the past and had finally given up trying to match colors in Revit. But, a company that I do work for is wanting to use exact colors for a presentation for the customer. In the photo below, the exact same color is used for the vertical trim, lap siding, and board and batten. They are all different depending on the material they are applied to. The image that Revit uses for the material seems to be the biggest factor. All 3 of these materials also don't look close to the Sherwin Williams swatch that I'm using for the RGB values. Is there are way to get more consistent results?
Kevin Mendenhall
Revit Architecture 2022
Microsoft Windows 11 Professional
Dell Precision 5870 - x64 based PC - Intel Xeon CPU @ 3.80GHz, 6 Core. 80Gb RAM
Installed Add Ins - Enscape/StrucSoft MWF/LotSpec
