COBie Toolkit for 2014, document tab
Hi, I'm using the COBie Toolkit for Revit 2014, and all the tabs in the excel sheet are exported as expected, however I'm having difficulties understanding how to fill the "document" tab. It is empty right now and I'm trying to figure out where should I add documents in Revit.
Can you please help me? This is for my thesis that I'm working right now
Ines Rodas
sureshchotrani
You need to model in Revit, some stuff will get populate there itselfSmiley Happy
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
I modeled my entire building in Revit and all the sheets are populated, however the document sheet is empty!!! Why is this?
Thank you,
Inês Rodas
sureshchotrani
Document sheet you are talking is under Schedule/Quantities, if yes then it should get populated itself if the Revit model is modelled in a correct way.
Slab as slab, wall as wall, roof as roof, etc
