Cobie Revit Integration
I have a query about interoperability of Revit and Cobie spread sheet and then importing that spread sheet inside Maximo.
Inside Maximo to Zoom in at a particular asset in 3D view we need a Parent-Child definition between the objects. And this information/relationship gets populated in "Assembly" tab of Cobie spread sheet.
I have a Revit model and using Cobie Add-in I export the details in the spread sheet to be used in Maximo. But somehow I am not getting any data in that "Assembly" tab.
Could anyone help me what changes I need to do such that I get those information (Parent Child relationship defined) in "Assembly" tab of Cobie spreadsheet.
JasonKunkel
The COBie Extension for Revit does nothing to generate information on the Assembly tab of the COBie spreadsheet.  Wish I had a better answer for you.
Without knowing specifically how the data you have needs to be consumed, there might be some workaround using the Attributes tab and a custom parameter?  As soon as I type that I am starting to doubt it.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
