Cloud Workshare, BIM 360, and Revit
Hey all!
I’ve been using Revit for a number of years and have fairly extensive experience with it. However, there is a lot of Revit that I have not used/explored. Some of which being the cloud work sharing.
At one point I had used Autodesk 360 or BIM 360 (been so long that I can’t remember the name) to collaborate on a project so that multiple people could be working in the model at the same time and sync. This seemed to work great and now years later I am wanting to set up a similar system. I understand that this has now moved to Collaborative pro, is this correct?
With all that being said, I am having trouble understanding/getting this system set up with Revit 2023.
My Revit Home Screen says “You currently don’t have access to Revit cloud models” and says that I need to subscribe to “Revit Cloud Worksharing” or cloud “Cloud Modles for Revit”
I have access to autodesk BIM collaborative Pro, Autodesk docs account with access to projects, and a Revit subscription. The one I am missing is access to the Revit Cloud Worksharing. Based on the autodesk help section I need to contact my administrator to be granted access to cloud worksharing. Trouble is, I am the administrator and can find no way to grant myself access.
I additionally cannot seem to get to the bottom of the cloud work share add-on and am unable to tell if I have it installed or not.
Has anyone run into these issues? Any help you all can offer is greatly appreciated!
Chances are I am making this much more complex than it needs to be…
Thank you!
