Void In Family Help Please
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
PhilvK
264 Aufrufe, 4 Antworten
The attached family is for a simple display case that is recessed in walls. The family flexes correctly but doesn;t work correctly when I insert it in a project. I believe the problem is with locking the various faces to the placement side of the wall. The back side of the trim pieces (red arrows) should lock to the wall face, and the glass face (blue arrows) should lock to the wall face. The void (orange arrows) should be competekly in the wall, not partially outside as in the 2nd image below. Any suggestions to fix this would be greatly appreciated.
4 ANTWORTEN 4
Nachricht 2 von 5
David_W_Koch
als Antwort auf: PhilvK
Your attached family did not come through.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Nachricht 3 von 5
PhilvK
als Antwort auf: David_W_Koch
Sorry, forgot to attach it. Here it is. and thanks!
Nachricht 4 von 5
Mike.FORM
You need to add a dimension from the ref plane at the face of the wall to the face of the wall (should be 0) and lock it.
Using align and lock between the ref plane and the wall face does not work.
Nachricht 5 von 5
PhilvK
als Antwort auf: Mike.FORM
That did the trick. Thank you very much!!
