- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Attached are two screen captures of two walls intersecting. Both walls have 6 in. metal studs with 5/8 in. gyp bd on the interior and 1/2in plywood sheathing just outside the exterior core. The exterior core is the location line for the walls.
Image A shows the vertical oriented wall stoping short of the horizontal wall. I would expect to see the studs and interior gyp bd wrapping cleanly.
Image B shows the end of the vertical wall pulled down just past the horzontal wall. the brick veneer comes throubh. I want the brick veneer to stop just short of the sheathing on the horizontal wall.
(Don't forget to use the backspace key to close the images. If you 'x' out you will be exited from the browser ((at least that's what happened to me!))).
