- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have made a corrugated wall cladding using Curtain Wall Mullions. What I need are the cladding lengths and count.
Following is a detailed scenario.
- Each cladding is 760 mm wide. If I make a 760 mm wide profile, it looks like this when attached to a sloped ref plane.
- But it generates a pretty accurate schedule of the count and lengths. But the cladding itself doesn't look good, and cutting it for windows and doors doesn't work well too as we can only cut a profile from its edge.
- Following is how it looks if I work with a small segment of the profile. I only created a 76 mm wide profile instead of a 760 mm.
- The problem comes with the schedule. Its schedule shows 10x more cladding count and lengths. I can deal with the count by assigning an integer and dividing it by 10. The problem comes with the Lengths. How can I make Revit calculate the maximum length of every ten mullions? Especially when we'll be cutting doors and windows too.
Please let me know if you need any further explanation.
Thank you
