Check marks icons in revit 2024
Richard.Vivanco
Advisor Advisor
Richard.Vivanco
Hi
In revit 2024 dont appear the check mark when you enable or disable an option.  Only change a little the size of the box.  Its normal or deppends the resolution of your monitor?  Im working with a 32" with 2560x1440px and the screen scale at 140%
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
mhiserZFHXS
Haven't noticed that issue, but I have seen some graphical glitches in the properties bar a few times. Hoping they're aware of such issues and get them fixed in the first patch.
HVAC-Novice
IIRC, you are supposed to run at or under 125% on 4K. But I never tried other than 100%. Maybe try that.
Is your view by any chance controlled by a template and you accidentally tried to edit the visibility overrides in the Graphics properties? if so, edit the template or use temporary view properties.
I have to say, this year the new version had no "have to have" features for me and is the first year I didn't convert my current projects right away. And this also is the first year where there seem to be so many problems. I opened a sample project right now to look this up for you. When moving the properties pane, it took some seconds for the properties pane to render properly. Maybe this new version doesn't like my ancient quattro P 2000, but that never happened before and we are just talking moving the properties pane. This year may be the year i don't upgrade my projects before the service pack is out.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Richard.Vivanco
I work with the same resolution in revit 2023 and dont see any error.
Another "problem" that I have detected is the definition of the letters that appears in the project browser, it looks with aliasing,  the properties panel or menu texts, looks better.
In 2023 version, all the texts looks great in the total interface.
In this case, maybe its a problem with my eyes, i dont  know, but i prefer narrow letters instead bold .
Richard Vivanco V.
