Wall core hatch lineweight issue
6 ANTWORTEN 6
Nachricht 1 von 7
Ian_H
552 Aufrufe, 6 Antworten
I can't seem to figure out what is driving the thickness of the wall core hatch. I know that lineweight 1 is for these and 2 is for ceilings. LW 1 is set to .001 but the hatch seems to be similar to LW 5 at .035.
My object settings for walls are 3 for projection and 5 for cut (see screenshot below). The common edges are thinner because they are being overidden to LW 01 (see screenshot below), but I don't know why they are thinner because LW 03 is the same thickness as LW01. When I change them to LW03 they jump to a similar LW as the hatch.
Screenshot of wall and LWs
Screenshot of Object styles
Screenshot of VGs
Is there another location I'm not thinking?
Beschriftungen (2)
6 ANTWORTEN 6
Nachricht 2 von 7
Ian_H
als Antwort auf: Ian_H
Let me know if I'm overthinking this because it is just an 1/8" drawing that I'm zooming way in on. Maybe I should just print out a test sheet and see what it looks like. Still, some of the behavior was odd when trying to adjust it.
Nachricht 3 von 7
constantin.stroescu
you can have an almost accurate view scale if you use shortcut command ZS (Zoom Scale).
If you use dual screen ZS will work only for one display
Constantin Stroescu
Nachricht 4 von 7
Is it an existing wall?  Do you have phasing override for existing?
Nachricht 5 von 7
Ian_H
als Antwort auf: ToanDN
I had forgot about phasing overrides, but no that wasn't it.
I'm going to table it for now since it doesn't bother the others on my team at the moment.
Nachricht 6 von 7
Hidden View vs. Wireframe View?
Nachricht 7 von 7
Share the phase overrides and your view's phasing.  Pretty sure it is it.
