Changing zoom levels mess up display colors of a surface
Hi everyone,
I am rendering some colors over a surface using SpatialFieldManager and AnalysisDisplayStyle. So basically I select the top face of a floor and then for different points on the floor, I have their RGB values. It works fine and I can see the rendered color surface. However, when I change the zoom level of the view for example with mouse scroll, this messes up the display colors on the surface. Following is the :
AnalysisDisplayColoredSurfaceSettings coloredSurfaceSettings = new AnalysisDisplayColoredSurfaceSettings();
AnalysisDisplayColorSettings colorSettings = new AnalysisDisplayColorSettings();
Autodesk.Revit.DB.Color blue = new Autodesk.Revit.DB.Color(0, 0, 255);
Autodesk.Revit.DB.Color red = new Autodesk.Revit.DB.Color(255, 0, 0);
colorSettings.MaxColor = red;
colorSettings.MinColor = blue;
AnalysisDisplayLegendSettings legendSettings = new AnalysisDisplayLegendSettings();
this.analysisDisplayStyle = AnalysisDisplayStyle.CreateAnalysisDisplayStyle(doc, "Colored Surface", coloredSurfaceSettings, colorSettings, legendSettings);
SpatialFieldManager sfm = new SpatialFieldManager(); sfm.UpdateSpatialFieldPrimitive(idX, new FieldDomainPointsByUV(points), new FieldValues(values), _schemaId);
L.Maas
I would advise to post this question in the Revit API forum.
Louis
Please mention Revit version, especially when uploading Revit files.
I think you are right. Thanks!
