Changing View's orientation which already linked to a scope box?
zefreestijl
zefreestijl
Hi, I just started learning using scope box to create view standard boundaries,
(thanks for the tips from Revit Pure : https://revitpure.com/blog/10-tips-to-understand-revit-scope-boxes)
It's great that I don't have to worry about each views if I settled up the correct scope box,
though the view orientation will always be aligned to up-to-down,
Is it possible to rotate the view 180° so that the view will be more readable when synchronizing with the Elevation view?
Thanks in advance :]
Not sure this answers your question, but the View Crop Boundary itself can be rotated and/or the View on the Sheet can be rotated.   Is this what you are after?
...the Marker itself can be rotated as well.
Rotate the scope box?
zefreestijl
Yes... That's exactly it! Thanks!
zefreestijl
Hi, Thanks for the response,
but the rotation on sheet can only be 90 degree.
someone just helped me out,
anyway, thanks for your help:]
That's exactly why I said to rotate the View Crop Boundary. Try it. Do both. Rotate on Sheet 90-degrees AND then Activate the View and rotate the View Crop Boundary. You'll see.
