Changing the scale of a view on a sheet, Revit uses an arbitrary base point. How can I change this?
When I change the scale of a floor plan view on a sheet, it scales from a seemingly arbitrary point. I would like this point to be at the internal origin, because this is where our referenced DWG files are based. How can I change where it bases the view?
I've shown the arbitrary base point by the reference plane crosshair at the bottom right, circled in red. Can anyone help?
1/4"=1'-0"1/4"=1'-0"3/16"=1'-0"3/16"=1'-0"1/8"=1'-0"1/8"=1'-0"
RDAOU
@Anonymous
  1. Enable crop and make sure the crop region is sized as necessary
  2. Select the View on sheet and set a Type with a View Title
  3. Move the View Title closer to the crop Region or Internal origin
  4. If you do not need the view title, simply re-select view and set one without a Title
Huh?
What do you mean by: "that is where our referenced DWG files are based"?
Thank you so much! I turned on the title of the view, and moved it to the internal origin.
We don't use view titles, so I had no idea it was there. Thank you!
It's complicated- basically we have a really inefficient system where I work. Our designers don't know Revit, so they'll design homes in AutoCAD, then I will import them into Revit and create the model based on their cad file.
I just wanted to change the scale of the view without it moving off the title block.
