Changing the materials available in the truss properties window
Message 1 of 26
I have Revit 2018.
I am trying to change the structural framing type of a truss.
In the Properties window, the only options currently available under the "Structural Framing Type" are "Set Framing Type" and "W Shapes: W12xX26".  I want "dimensional lumber" as an option.
How do I load in a different material, such as dimensional lumber, so that it is available as a framing type option in the Truss Properties window?
All of my attempts to load materials so far end in the error message "The family is not of the correct category."
Replies (25)
Message 2 of 26
Load the Type into the Project first.  If it's a Structural Framing Type, it should appear in drop-down list.
FWIW: if you load the Structural Framing Family and place one instance of it in the Project, and then draw your Truss, the Truss will use that Structural Framing member by default.
Message 3 of 26
- Insert menu > Load Family button > Load the Dimensional lumber family under Structural Framing
- Edit the truss type and assign dimensional lumber types to Chords and/or Webs
Message 4 of 26
Awesome, it worked. Thank you!
Message 5 of 26
Never fails. YOU come in and say the same thing I did and score the solution credit. What's your secret?  Being second?
Message 6 of 26
This is just a test post.
Message 7 of 26
Nope, that didn't work.
Oh well.
Message 8 of 26
The difference is that the other person specified exactly which menu to load the family from. Your information was useful generally, and will help to optimize future workflow, but it doesn't actually answer the specific question of "how to load the material" in this particular situation. I appreciate that you took the time to answer anyway.
Message 9 of 26
Huh? There's only a handful of ways to LOAD a family into a Project. You can any or all of them to LOAD a Structural Framing Family.  There no "special" way to LOAD a Truss member. Besides all that, the issue was not LOADING -- it was loading the correct CATEGORY. In your case, STRUCTURAL FRAMING MEMBER CATEGORY.
FWIW... "Material" (as in ""how to load the material") means something entirely different from what you are talking about.
Message 10 of 26
Sahay_R
I'm doing exactly as both of you say - when I switch the Structural Framing types, the webs and chords disappear!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 11 of 26
Is your view Coarse, Medium, or Fine?
Message 12 of 26
Huh?  Refresh my memory.  What did I say 9 months ago that doesn't work?
Message 13 of 26
Sahay_R
Fine.
Rina Sahay
Message 14 of 26
Sahay_R
Switched from this
to this -
and then the truss disappears.
Rina Sahay
Message 15 of 26
You don't say.
Pretty quirky.  Does it happen with other Materials too? Try Carpet.
Message 16 of 26
Sahay_R
The Dimension Lumber family also has the correct visibility.
Rina Sahay
Message 17 of 26
Sahay_R
Happened with the W section too
Rina Sahay
Message 18 of 26
Maybe the Motherboard inhaled some second-hand cannabis smoke?
Kidding.
Can you post the file?
Message 19 of 26
Sahay_R
@barthbradley - stop snickering....
Rina Sahay
Message 20 of 26
Sahay_R
Here you are.....
Rina Sahay
