Changing text color multiple times in a family
anne3SSZE
1,769 次查看
13 条回复
1 条消息(共 14 条)
anne3SSZE
Is it possible to change test color like this within the same text family so you can have multiple colors at once? I know how to change to color for the of the entire family but it isn't the best for note taking. Is there a plug in that exists that allows you to do this? Revit has a very basic text editor and I don't know why you can't just highlight some text and change its color like you can with most things, like this text box.
0 个赞
1,770 次查看
13 条回复
回复 (13)
2 条消息(共 14 条)
mhiserZFHXS
Not that I'm aware of, but Revit's not really meant for stuff like this. If you had a bunch of random colors all over the place, then you'd have to go and manually change all of them if that time came. The whole idea of types is that you make bulk changes at once. So you create a type that is used for one type of note, and use that where needed. Then if you ever need to change that, you only change it once and it updates everywhere.
0 个赞
3 条消息(共 14 条)
Yes.  Create different text types and assign them with different colors.
0 个赞
4 条消息(共 14 条)
You mean like this?
0 个赞
5 条消息(共 14 条)
anne3SSZE
_
0 个赞
6 条消息(共 14 条)
anne3SSZE
Yes! how do you do that?
0 个赞
7 条消息(共 14 条)
How much you got?  I can't just give it away for free.
0 个赞
8 条消息(共 14 条)
anne3SSZE
or like you could? 😕
0 个赞
9 条消息(共 14 条)
I'm just messing with you. That's an image imported into Revit.  You can't do it natively without a bunch of work overlapping different Text Types.  Been there; done that.  I think I would prefer root canal surgery over doing it again.
0 个赞
10 条消息(共 14 条)
mhiserZFHXS
Why would you go and get the poor person's hopes up like that...
0 个赞
11 条消息(共 14 条)
Actually, it could be a bone fide solution.  Try it yourself.
0 个赞
12 条消息(共 14 条)
Maybe use color filled regions to highlight instead of changing text colors.
Or create word document, export to PDF and place the PDF in Revit.
13 条消息(共 14 条)
anne3SSZE
thank you for the response those are some good suggestions but it won't exactly work for what I am trying to do. I have sheet notes that we leave comments on as reminders for things that might need to change in the text based on the project. Currently I have been using separate text boxes that are a different color but the issue is when text from the main body is changed the comments that are pointing to specific text will not move with the updated text. Adding filled regions to highlight will still leave me with the same issue of the region not moving with the text. thank you for the help though
0 个赞
14 条消息(共 14 条)
L.Maas
If it is in text box instead of colours make use of ALL CAPS, bold , underline, italic and things between [brackets] or a combination. If you want to bring more focus to the textbox you could use textstyle with particular fontcolour (or border around textbox) indicating that are comments in that box, then the text in bold/italic/... is the comment itself
After the comment is implemented you can replace the textstyle to your default.
Louis
Please mention Revit version, especially when uploading Revit files.
