changing template view with keyboard shortcut
philsogood
philsogood
hello
yesterday I intended to create a KS to change  quickly the view templates.
i realised that the window to assign template is different with the KS or when I click on the button :
i can't affect no template with the KS (the command name I use is "Apply Tepmplate Properties co current view)
i need to apply sometimes template view (when i'm modeling) then to be on "none" template because i need to apply others filters, hide elements (or i don't know what else!)
do you know if it's possible to have the same window for view template with the KS than with the button?
Phil
PS : the only solution is found is to create a blank template view "_NULL" but...
PrathapSekar
You can add keyboard shortcut for restore temporary view properties to disable the temporary view propertied applied to a view.
If your requirement is something different, Contact your local office development team and explain them the need, they may help you. we had a keyboard shortcut with the help of our development team (developed some dll files) to turn of link without opening the visibility graphics panel.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Why don't you use Temporary view properties button?  It lets you be free from the view template until you deactivate it.
You can even create keyboard shortcuts for them.
philsogood
thanks Toan, that's a good idea, i didn't think about it!!
Phil
