Changing Stair Width Affects Handrails
PhilvK
Advisor Advisor
PhilvK
I need to change the width of a stair consisting of a lower run, landing, then upper run. There are wall mounted handrails on each side. I thought you could change the width for the entire stair all at once, but I have to select each section individually and change the width. After doing that however, the handrails lose the association to the stair and run horizontal. Pick New Host or Reset Railing have no effect. What am I doing wrong please?
- Select the railing and use Reset Railing tool.  If it still does not fix then...
- Edit the handrail, align sketch lines to new run location, or delete sketch lines and recreate by picking run again.
PhilvK
Genius! Your second solution worked great. Thank you!
