Changing Level Linework Appearance
PhilvK
PhilvK
Is there a way to change the lineweight of the grid lines only for Levels. When I go into “Visibility Graphics”, I see that I can change the Level linework and Target to halftone, but I just want to change the lines.
cbcarch
Click on the Level, then in Properties, change the Line Color.
Please note that doing this will change the Type Properties for the Level Annotation, so all Levels of that Type will be changed.
If you need some Levels to NOT have the line color changed, Duplicate the Level Type, rename it, and change the Levels where needed.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
PhilvK
Thank you!!
