Message 1 of 10
06:25 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
@Anonymous
I believe That changes when you change or use a template...the English will be English; French would be French ....etc
hopefully you are starting a new project so there ain't much work to do (just start new and browser to a different one)
The thing is I have already finished my project. is there anyway I can transfer the work onto a new template ?
New with revit so not sure what to do now, though I can just change it at the end ...
HI!
I think, that this article can help you.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
@Anonymous
The only way to this is by using the right template...There isn't an easy way to it no (at least none that I know of)...you will have to do it manually and in steps.
There isn't an option which transfers all...ie:
not hard but tidious (would be nice IDEA if they would allow to open a project in a different template)
what you can do if you are a subscriber...put a ticket to Autodesk and see if they Could do anything to help you out. I think they can do it fairly easy at their end
@semko_dm if you haven't tried it before; that changes the language of the menus only! NOT THE TEMPLATE
Sent from my iPhone
Thanks, but does not work
I will try contacting auto desk
edit: nvm not a subscriber
@Anonymous
If you would be willing to read up on it a bit and start migrating the model; I would gladly try to help you along the way if you miss anything.
PS: can tag a couple of helpful Autodesk Support staff who are regularly on the forum maybe they could do something or help you out as a student (if I may assume that you are one)...
@loboarch @Rafal.Gaweda @Judy_S
I will have a read on migrating later
got any link on it ?
