Changing graphic for mass
I need to change the coarse cut surface for a wall mass inside a model group. I don't have the graphics options in edit type. What to do?
There are som screenshots to give a better idea what I'm talking about.
I hope someone have an answer 🙂
aleksei.tkachenko
I guess you need to be in "Edit group" mode in order to override graphics of this element.
I know, but i still don't have the option to change graphics of the wall. I want to change it to black in coarse mode and in fine is has to be the same as on the picture
aleksei.tkachenko
Ok. Why you choose mass for making this wall. If you use in-place generic model instead, you can put detail item into it. It can be black filled region for instance. Then you can make it visible only on coarse view and it will solve your problem.
