Changing Font Size (Not in Drawing Space)
Hello, I've had this problem and can't figure out the solution. The text height is too big in the windows. In the picture attached I'm in the Filter Menu and the text is cut off.
chrisplyler
I suspect you are going to have to set your Windows Display Scaling down to 150% or less.
That did the trick. Thank you.
Also, at the bottom of this link is how to solve the adjust the display.
http://help.autodesk.com/view/RVT/2017/ENU/?caas=caas%2Fsfdcarticles%2Fsfdcarticles%2FRevit-User-Int...
