Changing and adding Revit families using an ipad
scliffPRYVM
scliffPRYVM
I am a Revit user and i was wondering if there's an app that allows you to be able to charge Family Parameters or add in already existing Family when your in the field using an Ipad. For example if you were to go on site instead of drawing a red line onto the drawing where an receptacle in located you were able to place that receptacle in to the Local model on your ipad and be able to link it to the Centeral model either at your "home" computer or through autodesk cloud.
I would like to know if that software is available (e.i. BIM 360 field), if there's none like this, let me know for confirmation that there's isn't anything like this.
If any farther explanation need please comment.
Thank you
As far as I know, Autodesk BIM360 products provide nice mobile-accessible solutions but, none of them allow you to directly edit the model/information directly.
You can only communicate this with other people, but eventually, someone has to do the task using Revit on a desktop.
Regards.
