Change Witness Line Type
youssef.ibrahimM37J6
Message 1 of 21
Does Revit have any Capabilities for changing the witness line extension line type?Except for the Centerlines
Replies (20)
Message 2 of 21
RDAOU
@youssef.ibrahimM37J6
No there is no OOTB option which allows you to change pattern of the extension lines...ONLY possible for Centerline extensions.
If it is a must must and you cant work with the solid extensions, you will need to use a Line based Detail component which report Length in a label ... then you can have extensions of any line pattern
Message 3 of 21
Like this?
Message 4 of 21
RDAOU
@barthbradley wrote:
Like this?
That's a Centerline ... but Please do not advise him to overlay two Dimensions!!!
Message 5 of 21
It's a Dimension Type.  Nice try though.
Message 6 of 21
RDAOU
Nice try? Im not trying anything!!...
What you have there is a Centerline Dim without the centerline mark. The overlay of dims  was referencing the workaround for the OP's question on Witness Line pattern for DIMS other than CL
EI the below
Message 7 of 21
Calm down. You're going to have a heart-attack.   It's not 2 Dimension Types as you were presuming it was.  Nice try though.
Message 8 of 21
RDAOU
Barth...I think what you are experiencing is a little bit of both paranoia and anxiety 🙂 take a deep breath, read the OP question, what you posted and the advise given
Enjoy the day 😆
Message 9 of 21
OP asked: "Does Revit have any Capabilities for changing the witness line extension line type? Except for the Centerlines ."
I replied TO THE OP: "Like this?"
At this point, I'm waiting to hear back from the OP.
Stick around. You might learn something.
Message 10 of 21
RDAOU
I think you are hoping that he never replies back ><
Message 11 of 21
christiaan7KUDX
Could you please advise on how you did this.
Message 12 of 21
Don't you follow the saga?
Message 13 of 21
christiaan7KUDX
I did, I was just hoping @RDAOU was wrong. I should familiarize myself with this forum's lore.
Message 14 of 21
HN_arucker
So to clarify, the screenshot:
Was of a dimension with no witness lines and separate lines drawn in with line type set to Center?
Was of a dimension with no witness lines and a separate centerline dimension was placed?
Was of a dimension with witness lines whose line types were changed to Center?
If it was the last, how did you do it and would it affect only one dimension style or all dimensions?
Message 15 of 21
sajincv911
Hello
Message 16 of 21
sajincv911
hello, sorry for bringing back a closed topic. But i would like to know how these dotted lines were achieved as I couldnt find any line styles for witness lines in additional settings. is it a work around or a built in option?
Message 17 of 21
RogK
To those who go looking just for how to edit the dim style and find this
If you want to change the "witness lines" that's the lines that extend to the object being dimensioned its by clicking the dimension and then editing the type, then go to centreline pattern and select whatever line type you like
only thing is you cant do both in one go type thing as the original post kind was asking I think (just have two styles)
Message 18 of 21
neha_ligal
Hi, It only changed the central line dimension, what about the dimension that is not associated with centre?
Message 19 of 21
hakobh
EXACTLY!! That's the key question for me as well! (now that we are in 2026 almost)
Is it possible to assign custom line styles/patterns to specific witness lines (or even to all witness lines in a dedicated new dimension Type) that are tied to elements that have no "Center Line" characteristics?  For example to yellow-highlighted Top and Bottom witness lines in OP image.
Message 20 of 21
hakobh
Hey Youssef, could you reply if you found any solution since your 2021 post?
