- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
How do you change the thickness of already established split regions? Apologies if I am missing something really simple.
If you need more control over the line thickness in your views, you may need to adjust the line weights in the Object Styles or the Visibility/Graphics settings for that specific category
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
Autodesk Certified Professional
I was wondering if the layer thickness can be adjusted after you have created the split regions. Larger scales takes care of any line weight issues.
