Change the visibility graphics of several revit links at the same time
arq.mavariera
arq.mavariera
Hi everyone,
I am working in a big project with at least 30 files linked. I need to turn of some visibility graphics oh the linked file, so, I was wondering if there is a way to do it at the same time. For example, I do not want to see the walls of the linked files, but it takes to much time to do it in each linked file, each time.
Thanks!
David_Knight
Just an idea...
put the linked revit files in a specific workset you create.
use filters - by workset - and apply said filters.
might be less work to actually change your graphics in 'manage -> object styles' once for the whole project though, versus a filter for each view.
