Change the default settings for detail level of structural connections
joel.van.herwaarden
joel.van.herwaarden
Hi everyone,
This is probably not possible, but in Revit you only see your physical geometric representation of you structural connection when you set the detail level of a view to Fine. Is it possible to change this threshold to Medium?
I have views which are in medium detail level, but I want to see my connections. Otherwise I have to change multiple families to Fine...
Please let me know if there is a solution or a workaround.
RDAOU
@joel.van.herwaarden
I haven't been working with structural for a while but I remember that we worked around that by setting view specific Category Detail Level, Otherwise:
  1. Either having 2 views: First in medium with hidden connections and the second with Connections isolated then overlay them on the sheet
  2. OR by introducing into some of the structural families a Medium-Fine and a Fine-detail assigned to a subcategories where you can display a Fine detail in Medium View and vise versa by switching subcategories on and off
martijn_pater
You can set view specific detail level per category through visibility graphics (VV / VG) and ofcourse also include it in the view template optionally...  if not already.
view category detail level (preset)view category detail level (preset)
f.annoscia1XRNMD
It's interesting, thank you! 💙
