Instance parameters in schedules
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
NP---MD
670 Aufrufe, 3 Antworten
I have an assembly of curtain walls and curtain wall panels. There are a bunch of different curtain wall panel families. These families have a combination of type and instance parameters. The problem I now have is that I need to isolate and group every single unique family in this model. Basically I need Revit to differentiate between families of the same type who's instance param's vary in a schedule. Is this possible? Otherwise I'll need to embark on a process of converting all the instance param's back into to type param's and create many many more types in the model - something I'd love to avoid if possible!
Massively appreciate any help here!
3 ANTWORTEN 3
Nachricht 2 von 4
martijn_pater
als Antwort auf: NP---MD
Nachricht 3 von 4
NP---MD
Ah, I'm not! I'll look into the implicaitons of switching to these! Many thanks for the pointer!
Nachricht 4 von 4
RDAOU
@NP---MD
You can use View Filter. (Ex: make all panels which meet a certain criteria invisible - keeping the ones you want to isolate Visible) SEE LINK HERE
If the parameters you are referring to are the Curtain wall OOTB Type & Instance parameter then you shouldn't need any new parameters...Otherwise project parameters should do. (Shared Parameters would be useful in case of tagging)
