Change Schedule Text To All Caps Easily
JMS2-GLCD
Message 1 of 22
JMS2-GLCD
Hi Everyone, looking to see if there is a way to get all of my data in my equipment schedule to be uppercase.  My data is being pulled from my components being inserted.  Don't know if there is an easy way without having to type everything again.  Also, should I just use a font that only has capitol letters?  Any advise would be very much appreciated!
Replies (21)
Message 2 of 22
Hello @JMS2-GLCD
I think this is possible using a dynamo
Message 3 of 22
JMS2-GLCD
Could you elaborate a bit please...not sure what you are talking about, still a newbie here!  Really appreciate your time with this.
Message 4 of 22
Hello @JMS2-GLCD,
Here's the example using dynamo. find attached screencast.
Message 5 of 22
How did you build that Dynamo?
Message 6 of 22
Viveka_CD
Hi @Anonymous
You can download the dynamo extension HERE and follow the screencast by @Anonymous
Thanks @AnonymousSmiley Happy
Let us know if you were able to resolve your issue and if you have additional questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
Message 7 of 22
I have Dynamo installed but how do I make the one you show in the video?
Message 8 of 22
Viveka_CD
Hi @Anonymous
Please see the link HERE to change  text to Uppercase using Dynamo
Alternatively you can also use a macro HERE from archsmarter to change the text case.
Thank you,
Message 9 of 22
I need to change the text to uppercase in a schedule (ie. Panel schedule) that calls out family parameters.
The macro just changed leaders & notes
Does this make sense?
Message 10 of 22
Something like this:
Message 11 of 22
Hello @Anonymous
Follow on @ToanDN screenshot save it then run it.
Message 12 of 22
Can you please add the tread to follow from. I can't seem to find it
Message 13 of 22
How is this an acceptable solution?
Autodesk needs a few less engineers if this is what it takes to simply change the font.
Message 14 of 22
sascari
It's July 2021, and this is still the only way to change the font in a schedule? What are you guys working on at Autodesk?
Message 15 of 22
jeremy.thomas6
I'm so baffled why there isn't all caps check box just there built in to all fonts. Most architects used all caps in their drawings. But they type emails and documents normally, with lower and uppercase letters. So every time you go back and for the between notation in revit and typing somewhere else you're either in caps or not. ITS ETERnally FRUStrating. SO MANY OTHER PROGRAMS have and ALL CAPS OPTION, like a simple toggle... ComE on Autodesk - give us what we need - an all caps toggle on all fonts properties with nO mucking around - THAT WAT WE ONLY HAVE TO TYPE EVEYTHING ONCE...  thAt way we only have to typE everything once...
Message 16 of 22
Do a search on changing parameter case using Dynamo.
Message 17 of 22
yes_and_no
If Revit gives you what you need, how wd they sell new version every year ? It took 10 years to have them do revision cloud as simple rectangle instead of single segments...lol.
Message 18 of 22
hi where did you get that node having  both type and instance parameter?
Message 19 of 22
logansZU8H6
Where did you get (typeorinstance) nodes?
Message 20 of 22
skyeg321
Yeah I can't find that last box 'SetParameterByName'. When I search it all that comes up are these ones that have Element. before them. Do I need to import a library? @ToanDN
