Change Room Number Sequence to Every Other Number?
ballch49ZUG
ballch49ZUG
Can the Room Number sequencing be modified? For example, if I want to change the sequencing from 100, 101, 102, 103, etc., to be 100, 102, 104, 106, etc...? Or even something like 200, 300, 400...
vitorbortoncello
yes, you could manually change it in properties or automatically using plugin diroots reordering
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
ballch49ZUG
Which properties?
vitorbortoncello
ballch49ZUG
I appreciate your response; however, this does not change the sequence of the numbers. If I create a room, the number will be 1. If I change that number to 2, then create another room, that room will be 3. How can I make the rooms be 2, 4, 6, 8...? I don't know if it is possible without and add-in or Dynamo, but I thought I would ask in case I missed a setting somewhere. There are other tools in which the sequence of numbers can be altered, e.g. revisions.
