Change parametr from window to door window
have a problem change window parameter to door window.
At fisrt I cancelled heater (calorifero).
When try to change height sill (davanzale) it give me this problem.
It's depends on the formula for H heater ( h heater = h sill - 169+131)?
If unlock the two parameters go but I can't put 0 for h heater.
Alfredo_Medina
The height of the sill is too low: just 20 millimeters. Therefore 20 - 131 -169 produces the invalid value, -280, therefore Revit can't make the type with that negative value.
By the way, if you are interested, there's a forum for Revit in Italian at this link: http://www.cad3d.it/forum1/forums/41-Revit
Thank's for information.
But I deleted the heater.
Is however a problem?
Anyway if I click to skip the problem revit goes on next without problem.
Thank's for italian forum.
Next days I saw that.
Alfredo_Medina
Try deleting that formula if you don't need it, and the dimension that relates to that parameter.
No I delete the heater in family. This is the reason because I ask the reason of relation with the sill.
However click delete type it's gone.
Thank's!
Alfredo_Medina
You deleted the heater, yes, but you probably left a dimension there, in the view, maybe a dimension that was moving a reference plane, and the formula was trying to move that dimension in the opposite direction, to a negative value, which was not possible. It is important to understand the reason for the problem, not just delete things without understanding, that´s my point. OK...
Answer very comprehensive.
Thank's
