Change orientation of a model
advandes
Advisor Advisor
advandes
I have two separate Revit models: one is an overall arch and the other is a mechanical room provided by a 3rd party. The mechanical room was modeled 180 degrees and 200' away from the correct coordinates to match up with the overall arch. Is there a way to re-orientate the mechanical room coordinates without rotating and moving all the objects? I have already tried selecting all the objects in the mechanical room and rotating them, but I receive a few errors and some of the objects don't rotate. This was due to poor communication from an administrator, and now I have to fix it. Thanks in advance for any help!!! Aaron.
AAG
Advance Design
advandes
I forgot to add this: I would like to be able to link the mechanical room file into the arch file and have them orientated correctly by origin to origin.
AAG
Advance Design
Wouldn't it be easier to use a shared coordinate between a host and a link?
- Link Mech Room in Arch Building
- Relocate Mech link to the proper location
- Publish "Current position" of link instance to link file as a shared coordinate
- You can remove Mech link entirely and re-link it using Shared Coordinate.  It will come in @ the recorder position.
