change line type of existing (phase) footing
I have an existing phase footing which i'd like to appear dashed even when I am working on the new construction phase. please look at the attached image to understand the problem. The leftside/new footings are dashed while the rightside/existing footings are solid. Is there a way to override the graphics of linetype for the existing phase footings? Thank you.
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community! I see that this is your first post Smiley Happy
You can specify different graphics overrides for each phase status
  • Click Manage tab > Phasing panel > Phases.
  • In the Phasing dialog, click the Phase Filters tab.
  • Click New to insert a new phase filter.
    The filter is assigned a default name (Optional).
  • Click in the Filter Name box to edit the name.
  • For each phase status column (New, Existing, Demolished, and Temporary), specify how you want to display the elements:
    By Category: Displays elements as defined in the Object Styles dialog.
    Overridden: Displays elements as specified in the Graphic Overrides tab of the Phasing dialog.
    Not Displayed: Does not display the elements.
See the article HERE for more information.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
