Change Door Insertion Point
domhnall.omahoney
domhnall.omahoney
I have built a set of doors for a project, with the alignment to the inside of the wall.  However, the materials used for the walls will have limited tolerances.  Is there a way to move the doors to the centre of the wall?  In my head there should be a way to set up a parameter to change the insertion position but I cant find a specific guide on how to do so
Open an OOTB door family and you can see there is Inset parameter to set the location of the door within the wall thickness.
