Change Discipline on Sheets
I have created a number of sheets and noticed that the Discipline is set to Architecture and is Grayed out.  Can this be changed to Structural??
From you screen capture, I think you are looking at the properties of a View placed on a Sheet and not the Sheet itself (hint: Show Hidden lines parameter).  The View may use a View Template that set the Discipline value so that it is grayed out.
That makes sense.  I've only been using Revit for 3 days and jumped into an existing project that someone created a couple sheets already and I just continued to use them, and they probably did use the Arch Template.  Chalk it up to a learning experience.
