Hi @cargo33
Great,thanks for getting back!
Square columns are easier than the designer columns, and are lighter in your model geometry.
Ok, now we are talking about blending the column into two materials - one half to match the wall and the other half/ quarter to match the floor?
Is that correct?
Do you have any specific materials or color choices for the column/ wall and floor? Then we will start working with the custom materials. If so, send me the materials and screenshot of view to reproduce this and test for a workaround.
A few workarounds that we can try:
- Regarding the square column, we can try to break apart the column, created a specific family and load that into the project, or maybe try a split.
- Another option would be to create a custom material that matches the floor/ wall materials ina photo editing software and load that into the appearance library and apply it to the column faces.
- We can try assigning a light just to the columns to reflect this on parts of the columns like a light/dark appearance (I believe 3dsmax has more otions)
Sun light is fine for now, since you've posted an aerial view, I want to know if you have a 3d camera view in mind/ still image perspective? If you share your file, that wold help too. I can share a private folder if you'd prefer not to post publicly.
Looking forwrad to hearing from you.
