I'm trying to reduce the Projection Lines from casework / furniture in elevations (Image 01).
The exterior lines of the casework (and other furniture) keep printing quite thick. Is it something related with the family?
Image 03 (with Thin Lines activated) shows how I would like it to appear.
JP
Solved by bimscape. Go to Solution.
Can you upload the casework families?
Looking OK for me at 1:100 scale. (see attached screenshot)
What scale is the view set to (the one with the chunky lines)?
I've just managed to figure it out! It is something related with a definition in a View Template: changing to other View Templates reduces the overall thickness. Now I just need to figure out which parameter it is...
Thanks for your quick reply anyway!
Cheers,
JP
Excellent!
For those who are searching the archive for the answer where template was changing the thickness or appear to be whilst changing lineweight doesnt do anything. Go to model display and change silhouettes. For me it was making handles and outline very thick.
