change case
change case
Message 1 of 23
change case
Hi!
Can you tell me please how can I change in Revit upper case text to lower case or opposite?
Thank you
Replies (22)
Message 21 of 23
Keith_Wilkinson
Fair point, although, if that's the lengths you needed to go to you'd probably be better off copying the data and modifying it in a dedicated word processor to get it how you want it then paste it back in. While the Revit text tools have improved they are still pretty basic in comparison to a dedicated platform.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Message 22 of 23
j.hutchingsEYDMZ
To be honest, I find that it's enough to use a tool for generally changing the case, and then tweaking it manually afterwards.  Why? Because there are so many "special cases" where I don't want something changed to lower case.  For example:
"20 MPa concrete"
"as per OBC 3.2.2.2.(4)(b)"
... and so on.  Even if I spent time trying to program (Dynamo, PyRevit, or a macro) all these exceptions, I could never be sure there wasn't something I hadn't accounted for, and would have to read it over anyway.  So it would be a lot of effort for little gained -- at least for my situation.  Therefore, using a quick-and-dirty method for converting uppercase to sentence case is good enough.  So whether it's PyRevit or an online case-changing tool I keep open in my browser, those are sufficient for me.
Message 23 of 23
Jim_Melin
When editing Revit text-objects the text editor you get a toolbar that offers changing case.
It can only change text in one text-frame at a time.
But it has issues with special characters like Åå Ää Öö and Üü Ïï when Revit exports to DWG.
A Revit bug makes these remain as lower case in the DWGs.
Kindly
Jim Melin
AEC AB CAD Solution Support
_______________________________________
www.aec.se
