Central File Corrupt Manually Recover Contact Autodesk Support
I went to open a Project file in REVIT 2015, and I received an erro message telling me the file was corrupt Manually Recover Contact Autodesk Support. I tried to open the Bak files that were saved; they also were corrupt. Is there anything else I can do?
Larry
L.Maas
Try to open the file with "Audit" selected and see if that helps.
If that does not work and if you are on subscription, you can go into your account and create a support ticket with Autodesk. Sometimes they can manually recover the file.
Louis
Please mention Revit version, especially when uploading Revit files.
www.TechRoom.bg
Audit is standart solution and work perfect but HERE is Autodesk official post for this problem. They give you more options to try if Audit dont fix your problem.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
