How to remove end tread in the stair?
8 ANTWORTEN 8
Nachricht 1 von 9
Hung.Pham
5620 Aufrufe, 8 Antworten
Hi Guy,
Currently, I have a problem with Stair. Can you help me?
When I created a stair by component or sketch with my template, the Treads run as picture below.
But when I try to created the stair with default templates (Metric/...) the Treads is corrently.
The stair settings is same.
In my template.
In Metric setting
How to fix the problem? I want to remove the end tread in stair.
Thank you so much.
Hung
8 ANTWORTEN 8
Nachricht 2 von 9
ennujozlagam
als Antwort auf: Hung.Pham
hi, edit stair and pick stair and go to properties. hope it helps. thanks
please see attached.
Nachricht 3 von 9
Hung.Pham
als Antwort auf: ennujozlagam
Thank you so much.
Nachricht 4 von 9
ennujozlagam
hi, if your issue is solve please mark as solution and kudos gladly accepted so we can move on. thanks.
some sample of stair.
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/screencast/Main/Details/5...
Nachricht 5 von 9
Has this function been removed? I am working in 2017 and having the issue that my top tread is not showing up.
I cannot find this option in the stair properties.
Nachricht 6 von 9
als Antwort auf: Anonymous
Did you check the End with Riser option of the stair Run?
Nachricht 7 von 9
als Antwort auf: ToanDN
Not sure where this option is located to check.
I have dug through the properties of the assembled stair family and the run type of under the construction heading, but am not able to located the setting.
I've attached a few images.
1st is a section of the stair. as you can see the top tread is missing.
2nd is the properties box for the assembles stair
3rd is the properties for the run type construction.
Nachricht 8 von 9
Found It!
you need to select the stair and click the "edit stairs" button to get the stair into sketch mode. With the stair selected in sketch mode, the options for "begin with riser" and "end with riser" are available in the properties.
Nachricht 9 von 9
@Anonymous wrote:
Found It!
Yup, glad you found it!
That's why I said "stair Run" and not "stair".  A stair can have several Runs and each of them an have a different End with Riser option.
