Ceilings - Invisible but selectable
craig_SW
craig_SW
Hello Hivemind,
The ceiling in a project have all gone invisible. They are still selectable and even tag.... but they are invisible. I'm and advanced user so have been through all the usual, VG, Workset etc. Is it possible the structure or material could be causing this?
Thanks.
Well, if you checked Visibility Graphics...did you check to see if they are set to 100% transparent?
Then the next thing to check is the material of the ceilings set to 100% transparent?
Cool. Can we see the file. I figure you've thought of everything I would if you're an experienced user.
Luiscko
I thing you have your celling whit no hatch and this is the reason that you see like it does not appear, another thing that you maybe have is that your view range is not enought high to see the element but closely to tag, i recomend you that you check your view range and your discipline filter and the last check if you do not have overlay your view and you tag another element.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
craig_SW
It's a commercial project, not possible.
craig_SW
Resolved.
One of the team had adjusted a shaft opening, hid it and didn't tell anyone...
