Ceilings are Acting Like Mirrors- Revit Rendering
Hi All!
My rendering continues to show up with the ceilings and walls acting like mirrors. I have even tried replacing all window walls with solid walls to see if it was a reflection issue. If someone could give me some insight, as I am the only one using the program at my work.
Thanks!
L.Maas
To me it does not look like a mirror effect. It looks more like transparent. Have a look if your ceiling material to see if it has a transparency setting applied.
Otherwise consider uploading (part of) your project so we can have a look.
Louis
Please mention Revit version, especially when uploading Revit files.
MichaelBussiere2
Thank you for your post.  It looks like form the image you have some mirroring and/or transparency settings causing ill render outputs in the supplied image.  In this case, I would agree with “Louis” about checking the transparency setting to see if this adjustment can then minimize this effect.  Additionally, if this should not work, please reply back with a sample copy of the model for review. This will help the group identify what could be contributing to this ill effect past the transparency possibility.
Changing the material properties: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
Please also refer to the below link in regards to the tips and tricks for rendering outputs.  Granted it is a little older, but there are some good tips in this that may help.   Thank you and please keep us posted in the community.
(tip 4/5): http://revit-detail.blogspot.com/2010/02/7-render-tips.html?_sm_au_=iVVM8MRs84TsHVH5
(tip 1): http://revitclinic.typepad.com/my_weblog/2009/07/10-rendering-tips.html
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
