Curtain walls won't embed into wall
16 ANTWORTEN 16
GELÖST
Nachricht 1 von 17
gnarkill283
18311 Aufrufe, 16 Antworten
Curtain walls refuse to embed into walls. I've tried copying similar curtain walls from other floors into the same spot. I've tried using the cut command but it only lets me select curtain wall components such as a mullion. This is occurring when changing the exterior wall and trying to place the window back into the new walls.  The curtain wall doesn't cut the wall and just shows up outlined inside the wall.
16 ANTWORTEN 16
Nachricht 2 von 17
als Antwort auf: gnarkill283
Automatic Embed setting is under Type Properties.
You can also use Cut Geometry to cut the Curtain Wall from the Wall if they overlap.
Nachricht 3 von 17
gnarkill283
als Antwort auf: ToanDN
Both of those don't work
Nachricht 4 von 17
You need hover around the edge and TAB until you see a dashed outline and the bottom status bar says Curtain wall when using Cut Geometry.
Nachricht 5 von 17
gnarkill283
Yea that doesn't work. I've hovered around clicking everywhere. Nothing gets highlighted and when I click something it usually only picks a component and does nothing. Do you want me to post a video of it?
Nachricht 6 von 17
No need for your video.  Uncheck Curtain wall panel and Curtain wall mullion categories from VG and try again.
Nachricht 7 von 17
sharrison
Must be a bug; I found that deleting the wall you want to embed the curtain wall in and reapplying it should pick up the automatically embed parameter and the cut command. I found this usually only happens when copying curtain wall elements and rotating them.
Nachricht 8 von 17
stevie_kelly
als Antwort auf: sharrison
@gnarkill283 @ToanDN I know this was ages ago, but I was having the same issue today. it turned out that either my wall or my curtain wall was slightly off axis and when I fixed that, the curtain wall embedded automatically.
Nachricht 9 von 17
ericksong
als Antwort auf: stevie_kelly
Stevie, you saved me hours of messing around. My wall was off a few degrees due to survey accuracy. Cut right away after aligning curtain wall. Thanks a lot.
Nachricht 10 von 17
als Antwort auf: ericksong
Thanks for the info.
Unreal that Revit has to have perfectly aligned walls. What about existing conditions? What about creating a model that replicates existing conditons where walls are NOT perfect? Amazing. Autodesk really needs to get acclimated to those of us who are using scanned data to replicate existing conditions so that our remodels actually work.
Nachricht 11 von 17
als Antwort auf: Anonymous
Curtain wall tool is meant to create vertical systems and they only embed into vertical walls.  If your walls do not meet the criteria then cut it using other means such as a void or an opening.
Nachricht 12 von 17
g_leblancCT9MX
thanks for the video but in my case, once I click on the ''cut geometry'' icon, I can select the wall but the curtain wall won't show!! it shows before when I hover on it, but not after I click the icon.... I dont understand how to fix this. Is there a way to setup the curtain walls to automatically imbed into the wall ,not just in plan view but in the elevations/3d also, just like any door or window?
Nachricht 13 von 17
g_leblancCT9MX
in my case the box is checked, the opening created by the new curtain wall shows in plan view but doesn't happen in elevations or 3d.... how do you fix this?
Nachricht 14 von 17
kris.kencevski
I am having the same issue, I have selected automatically imbed, my wall is on axis, I tried the above video with no improvement, and tried removing the wall in all ways imaginable and it's still not embedding. It works for some curtain wall but not that one I need. Any other updates?
Nachricht 15 von 17
Architex2000
als Antwort auf: kris.kencevski
Try grabbing the grip at one end and shortening the wall, should then cut in. (worked for me) then drag the grip back to the original spot
Nachricht 16 von 17
s45560552
Thanks, worked
Nachricht 17 von 17
SteveKStafford
Old thread with recent update...I'll add, curtain walls will automatically embed (if that type parameter is on) IF it is aligned with the "host" walls center line. Once it is embedded you can usually move forward or backward in the wall's thickness to adjust where the curtain wall is within the host wall. If you try to sketch it away from the center line it may not automatically embed...so I always sketch it right over the center line and then adjust. It's always been more reliable this way.
Steve Stafford
