ceiling tag to read as spot elevation (top or bottom elevation)
jledgewood409
Message 1 of 13
jledgewood409
i would like to have a ceiling tag read the way a spot elevation reads the "top elevation" or "bottom elevation" of an element? for instance, in an RCP i would like the ceiling tag to read the underside of the ceiling (gyp.bd.) or "top elevation"
Replies (12)
Message 2 of 13
Yes. Look at your Options Bar when placing Spot Elevations...
Message 3 of 13
I thought a ceiling tag always reads the elevation of the underside of a ceiling, which is the bottom elevation.  Or do you want the elevation of the top of the ceiling?
Message 4 of 13
jledgewood409
in your description it would be the top. I am looking to tag the side of the ceiling between the ceiling and the structure.
Message 5 of 13
jledgewood409
I would like to create a ceiling tag that acts like the spot elevation in that I can tag the underside of the element e.g. the gyp.bd. ceiling. my ceiling tags right now have the label enclosed with a rectangle and I would like to keep that look with this new ceiling tag that reads the underside (top elevation)
Message 6 of 13
Message 7 of 13
You could get it by some ridiculous calculated value in the tag itself.  But why just not use a spot elevation?
Message 8 of 13
jledgewood409
we are getting there. so if the ceiling element is 5/8" gypsum board and is set at 8'-0"  in the typical ceiling tag it would read 8'-0". we set our ceilings so that the top side would read 8'-0". meaning we would set our ceiling height to be in this case the thickness of the ceiling 5/8" lower so that the tag will read 8'-0" (bearing height if you will)
I hope this helps in what I am trying to accomplish.
Message 9 of 13
jledgewood409
can I create a custom spot elevation to look like my ceiling tag. see attached
Message 10 of 13
You mean a Spot Elevation without an Arrowhead or Symbol?
Message 11 of 13
jledgewood409
essentially yes. I would like to add a rectangle (box) around the label so that it looks like our current ceiling tag. per my attachment
Message 12 of 13
I'm sure I could figure out a way. But, I got you almost there.  That's my contribution today.
Message 13 of 13
Create a Spot Elevation symbol family with a box and load it in your project.  Edit a Spot Elevation type and use the symbol.  After place a spot elevation, just drag the label inside the box.
