Ceiling Plan not showing up
elky853
Message 1 of 10
elky853
Hi all, I'm having an issue creating a Reflected Ceiling Plan in Revit (Revit 2021 Student Version). I created the floor plans for that project and even added a ceiling (in floor plan view) but when I click on Level 1 ceiling plan in the Project Browser nothing shows up. I checked my view range settings, visibility graphics, and anything else I thought might cause the issue. What could be causing this issue? Thank you
Replies (9)
Message 2 of 10
Check your view range settings.
Message 3 of 10
elky853
Thanks for your reply. I checked the View Range settings and it looks fine. Please see the attached screenshot.
Message 4 of 10
syman2000
Can you check the 3d view and see if ceiling is in your 3d object? Also check and see what phase your ceiling plan is set to.
Message 5 of 10
Bet you one dollar that one of these 33 applies:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Message 6 of 10
elky853
The phase was previously set to 'project completion' and I changed it to existing and it's finally showing up now!! Thanks so much for your help, syman!
Message 7 of 10
Dirk77
I had the same issue-result as OP, but @barthbradley 's link reminded me I had a filter for the linked ceiling set up ages ago. Just saying thank you as a side note.
Message 8 of 10
kumardasrat595
Community Visitor
Community Visitor
In my revit software ceilng plan is not showing, can anyone suggest me how i insert ceiling plan.
Message 9 of 10
ghazal_hajijafari
Community Visitor
Community Visitor
Worked perfectly - thank you sooo much
Message 10 of 10
MegLizHen
New Member
New Member
Been checking everywhere to find a solution to this problem, you're the only one to mention changing the phase. Mine was in Project Completion, had no idea. I was going crazy trying out every View Range and Underlay setting alongside checking Visibility that had everything checked, those seemed to be the only solutions anyone could come up with. I don't understand why Revit would make these plans set to different Phases, I certainly didn't change them.
