Ceiling pattern distorted
chiehchih.chiang
chiehchih.chiang
I'm having problem applying patterns to a Revit ceiling.
Image 2Image 2Image 1Image 1
The same pattern gets distorted in different views even when aligned to element (First image) and the spacing is different within the same image (Second image).
I like the left perspective view better than right one. Go with the Left.
Kidding, but curious.  Following...
...one thing I've noticed with perspectives, is the more you mess around with the cropping, the worse they get.  Sometimes starting over works better.
Is it a model surface pattern from the ceiling material?
What are the Graphics and Hardware settings line under Options?
Is that a Drafting Pattern or a Model Pattern? I suspect Drafting. Try Model.
chiehchih.chiang
Thank you folks!
