ceiling doesnt want to apply in a specific space
Message 1 of 11
im trying to apply ceiling in that space but it doesnt want to. what is wrong there?
Replies (10)
Message 2 of 11
Is the space completely bound by "Room Bounding" elements?  No gaps?
...or Sketch the Ceiling
Message 3 of 11
yes it is bound i have no idea what is wrong?
Message 4 of 11
It's more than likely that your walls don't extend up to the height of the ceiling.  Check your wall heights, and ceiling placement heights
Message 5 of 11
it is but still doesnt want to. it is so weird.
Message 6 of 11
Try and create the ceiling at a lower level - say 500 mm and then move it up after.  If that doesn't work then do as BarthBradley suggests - sketch it.
Message 7 of 11
Do all bounding walls exist in the Phase?
..you know, you can always post your file.
Message 8 of 11
i tried before a couple months ago to do a celing which intersects with
curtain wall and it went fine, dont know what is wrong this time
Message 9 of 11
You might also check if any of the walls are part of a design option.
Message 10 of 11
We're aware that you don't know what's going on.  So post the file.   We'll figure it out.
Message 11 of 11
what do u mean design option?
