Ceiling Boundary Line not Plotting as Shown.
Trevor_W
Message 1 of 27
Trevor_W
TLDR: Thick line at the edge of ceilings is not printing out as a solid line.
In our reflected ceiling plan, we use Visibility Graphics > Ceilings to set the projection line to a thick line. It looks perfect before we print. If we print or make a PDF, the ceiling boundaries do not show up as solid lines. They appear to break at random points. My "fix" has been to draft lines that are locked to the edges of ceilings, but this feels like a redundant step that VG settings should have fixed.
In the attached RCP, I am cutting all walls, and ceilings are flat.
Am I missing something?
Replies (26)
Message 2 of 27
cbcarch
A couple of questions:
-Are you printing directly to a printer/plotter? What settings? Color or B&W?
-Try printing to PDF, w/ High or Presentation Quality / Vector ( or try Raster ) --then print paper copy from the PDF.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 27
Trevor_W
thanks Cliff
I have tried printing directly, and I have tried creating a PDF (our typical workflow). The results are the same.
I am using Vector processing, and color.
Just to double check, I did print the PDF with bad lines, and it does in fact print just like the PDF:)
Per your suggestion, I did try Raster. Raster DOES show complete lines, but it's a Raster image and will interfere with some of our Quality Control procedures.
Message 4 of 27
Is the box below ticked or not?
Message 5 of 27
Trevor_W
Toan
That box is not ticked.
I checked the box and tried a new PDF. The lines were all thin.
It's a vector, and it's a consistent line weight, just not the weight I want. 🙂
Message 6 of 27
What is the View Range cut height?  It isn't right at the face of the ceiling, is it?
Message 7 of 27
Trevor_W
*update: add screen shot of print settingsPrint SettingsPrint Settings
Message 8 of 27
Trevor_W
in this sample model, I'm cutting at 7'-6" and have an 8'-0 Ceiling height
Message 9 of 27
Can you share the sample model?
Message 10 of 27
Trevor_W
I'm working in our template file right now, give me a bit and I will set something up that I can share.
Message 11 of 27
Trevor_W
can you download it here:*edit never mind, see below.
Message 12 of 27
Trevor_W
sample file attached?
Message 13 of 27
I can only fix it by turn on transparency for walls category and set bluebeam to line merge.
Message 14 of 27
Trevor_W
Toan
I have never messed with the Line Merge settings before, I'll mess with them some more today.
Transparent walls with Line Merge (Multiply %100) almost works. I'm not going to implement this in our template just yet, but I'll definitely keep this idea in my "tool box".
in_projectin_project
Message 15 of 27
Viveka_CD
Hi @Trevor_W
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
Message 16 of 27
Trevor_W
No, still haven't found a way to PDF what I see on my screen.
Message 17 of 27
Viveka_CD
Hi @Trevor_W
Can you confirm if you've installed the latest updates for your Revit version?
Did you try printing to PDF with another PDF printer, other than blue-beam?
Message 18 of 27
Trevor_W
Revit v: 18.3.0.97   20180329_1100(x64)
I have tried 3 Printers to print directly from Revit. They each printed with broken ceiling lines.
I've only used Bluebeam for PDFs. I've used the Add-In controls to PDF, as well as the Revit Print settings to PDF.
No luck.
Message 19 of 27
Viveka_CD
@Trevor_W
Good that you are on the latest version!
Yes, I tested your file with few other PDF printers and get the broken lines as well.
Let me test the file further.
Message 20 of 27
Trevor_W
Viveka,
Thank you for looking into this. I hope we can find a solution.
